Hi all, can anyone tell me what I'm doing wrong here?
I have a bathroom extractor with a humidistat and over-run timer (no pull cord). I would like the fan to come on when the humidity reaches 40% and switch off 10 mins after the humidity drops below this level - I've set the variable controls accordingly.
I have it on an isolated switch which is outside the bathroom, in a cupboard, and not linked to the light. (This would have been my preferred set up but I didn't want to go through the significant disruption to wire it to that side of the room).
There are 3 ports on the fan, marked L, N and L-T. From my switch, I have wired it like this
N : blue
L : brown
L-T : empty (there is a diagram next to it showing it's a switch from the L, unsure if that's a standard convention)
When I flip the switch outside the bathroom, the fan comes on and then switches off after 10 mins - as expected. Then if I turn the shower on, the fan comes on after a few minutes - but then it never switches off, even after the room is no longer humid. I had thought I could just leave the switch outside permanently on and then the fan would come on when it was humid, run for a while and switch off 10 mins after it no longer detects humidity.
Have I wired it wrong, or mis-read how it's supposed to work?
N : blue
L : brown
