Bathroom Extractor Wiring
5 Nov 2008
For a shower extractor fan where does it normally get powered from.
The ceiling rose or the pull cored light switch?
As the fan requires a Neutral.
Where would you expect that to be.
you should take a feed from the light fitting
to a fan isolator switch
then from the fan isolator switch to the fan
and dont forget part p :D
Does the fan require
live and neutral
or
permanent live, switched live, and neutral
Also not forgetting that the Manufacturers Instructions may stipulate a 1A or 3A fuse to protect the fan.
