Dear All,
I am considering fitting a new externally mounted extractor fan to remove air from a new toiletroom and seperate shower room.
If I do in fact do this then this will be notified to Building Control or installed by an Electrician.
I have a few questions I would like assistance on:-
1. The fan will have no timer and will be controlled via a switch on the wall. This will be on the same switchplate as the light switch. With this in mind will I require a separate 'Fan Isolator' switch. Surely the switch on the wall is used for fan isolation purposes.
2. The fan will be connected to the downstairs lighting supply. Am I required to provide an inline fuse (FCU for example) to separately fuse the fan or if I wish can I rely on the MCB in the CU.
Many Thanks
Paul
Many Thanks
Paul
