Bathroom fan heater installation
12 Jul 2017
Anyone have installed a bathroom fan heater yourself? or is it advisable to get an electrician to install it for you? If electrician install, does the electrician drill holes and mount it for you?
Is it okay to install the fan heater at 45 degrees angle? Due to the tiny bathroom, I cannot install the fan heater directly above where I need it to blow. I am thinking if I angle it at 45 degrees, it will be able to deliver the warm air to shower exit, where I need it the most.
Any other tips you'd give for heating bathrooms?
Many thanks
Yes.
It sounds like it would be advisable.
Yes.
That would be down to the manufacturer's instructions.
If it is in a relatively warm building (not really draughty) then a heated towel rail may be adequate.
Thank you for your quick and detailed reply.
I downloaded the install instructions and it seems it must be fitted horizontal. :(
https://www.tlc-direct.co.uk/Technical/DataSheets/Dimplex/DXFX20VL.pdf
We do have a towel rail and it had been turned up to maximum. But it only heats the bathroom to the same temperature as the rest of the house. As a result, still feel cold when coming out of a hot shower. I'm hoping directed warm air will fix that feeling.
I don't think it would.
That would require the room to be at the same temperature as the water, 40°C ?
I would have thought that blowing air, even warm air, onto a wet body would cause the wetness to evaporate and therefore cool the body ('latent heat' and all that). After all, that's how dogs cool themselves down - by blowing warm air (from their lungs) over their wet tongue.
Once you've dried yourself, the fan heater ought to make you feel warm, but, as above, I suspect that until you are dry, it could well make you feel cooler/colder.
Kind Regards, John
