Hi All,
I have a rather ancient (~1960's) extractor fan half way up the wall in my bathroom. The on/off switch is operated by the steel shutter on the front of it. The fan (and shutter etc) is earthed and on the lighting circuit.
A few inches above the fan is a std size connection unit box (not fused, not switched) set in the wall with a plain cover on the front. Inside, it used to have ceramic screw-type connectors on each wire to connect fan flex with house cable. It now houses a chocblock.
Question:
In time, the fan will probably be replaced with a modern unit, but current one is working fine but I would like to add, at the very least, an un-switched FCU. I know we don't put sockets in bathrooms ( ) and lights are operated by pull cords, so what about my FCU for this fan? Is it acceptable to use the existing box in the wall, or should it be outside the bathroom? Would it make any difference if the FCU had a switch?
Thanks for your advice!
Question:
