Hi, dunno if this is the correct forum to ask this but I am changing my bathroom around totally to how it used to be and I was wondering what the best way to alter the extraction setup would be.
Currently, there is one vent hole in the ceiling, about 500mm away from where the old bath used to be. This runs straight up into the loft through about 400mm of insulated rigid ducting, through a 90° bend and into a Manrose MF125T fan set for a 12 minute overun, then roughly 6M of insulated rigid ducting (with a fall of about 100mm) to a gravity shuttered opening in the gable end.
Currently this works perfectly, extracts the steam from baths/showers great and the ductwork is always dry.
I have extended the bathroom by about 1M and am going to fit a separate walk-in shower at the opposite end to the new bath. The glass panel will only be 200mm from the ceiling so I should imagine the steam from a shower will be concentrated in that area.
Looking at parts that are available, I was thinking of moving the fan unit slightly over one way, fitting a Y-Piece to connect to the existing ceiling outlet and then running approx 1.6M of fresh rigid duct to another ceiling outlet above the shower. Does this setup sound like it will work OK ?
Also, is there an effective way of cutting down the noise the fan makes ? I'm guessing it's the actual airflow which is causing the most noise as the fan itself can hardly be heard at all when there's no ducting connected. I was wondering about not letting the actual ductwork physically touch the fan body (by using 50mm wide neoprene tape and supporting the ductwork separately) but I'm prepared to put up with the noise if it means the extraction rate is still good.
Finally, can an electrically operated louvre shutter be fitted to this setup that would open/close automatically dependent on the fan running as when the wind is blowing and the fan isn't running the shutter rattles like buggery, to the point of almost waking us up some nights.
TIA
TIA
