Hi All
The fan in my bathroom is connected into the Lighting Circuit in the usual way using 3 core and earth. Red perm live, Yellow Sw live, Blue Neutral and Green/Yellow earth, There is no Isolator switch fitted which I intend to rectify ASAP .
My question is this, while fitting a 3pole Isolator switch is it allowed to move the wiring from the Light circuit to the shower switch using the perm live, switched live, neutral and earth which are all present in the switch. basically so the fan works when the shower is used rather than everytime we switch the light on, Or is this not advisable.
I would also intend to fit a non switched fuse into the wiring after the Isolator.
Last question if all this is possible is it something I can do Or do I need the services of an electrician.
Mnay thanks in advance.
