i have just bought a bathroom fan (timer) could you please tell me how to wire it up and do i need a fcu, i am connecting it to a 5 amp lighting curcuit, if so what size fuse is needed in the fcu
This is not much help, I know, but I am surprised there was no connection information with the fan. Was it incredibly cheap? That and no instructions smells of a non-compliant import.
yes there was instructions and they say i need a fcu with a 3 amp fuse but i read somewhere else that i don't need an fcu when wiring into a 5 amp lighting curcuit, can you help please
My approach is to put as many service switches and fuses as there are powered devices (ie fan) That way, when you inevitably have to work on it, you do not have to switch off the whole circuit. It costs a tiny bit more for the extra future convenience.
If in any doubt about bathroom electrics, get a qualified professional electrician, as the bathroom is classed as a high risk area under BS7671:2001 wiring regulations, with its high electrocution risks.
