Hi All
Im currently stripping out my bathroom, its a modern house and has chipboard floors (about10-15mm thick) and dot and dab plaster walls. Where i have removed a leaky shower there is no plaster behined so i need to put up new plasterboard. Is the splashproof pink stuff ok to use or do i need something more substantial. The bit thats being replaced will be at the shower end of the new shower bath.
Also i would like to tile the floor, ive read somewhere that i need to replace the floor with OSB board ?? then coat it in sealer then i can tile. This seems a bit much, other people have said its ok to tile direct onto the chipboard, but just to use flexible adhesieve.
So id like anybodys advice before i start.
Many thanks
Mike
Many thanks
Mike
