Hi all, my 1st post here
We're planning a refurb of the bathroom and want to put in a new steel bath. However, the bath will be alighned with the floor joists (170mm x55 @ 370mm apart Edwardian house). The bath weighs 55Kg with capacity of 150 litres (150kg) so say 205 kg when full. The feet wont be resting directly on the joists and are 480mm apart width ways. One set of feet will be 600mm from a load baring wall and the other 1440 from the same load baring wall and 1560 from the other load baring wall. The floor will be either 18mm ply or 22mm ply screwed down.
My question is will we end up with the bath in the kitchen below the first time we fill it or will this be ok?
Oh and we want to tile the floor with 300mm square slate tiles. Obviously the thicker the ply the better but as the bathroom is only 2m x3m max with joists every 370mm running across the width of the room (2m) would 18mm be ok (save weight on the joists)?
cheers Rob
ps great forum guys!
cheers Rob
