I have inherited a wetroom with floor tiles and underfloor heating.
Plan is to put a bath in.
I had concerns previously about the combined weight of the floor tiles, screed for ufh when adding a bath. I was reassured that the additional weight of a bath, the water etc isnt more than a few people.
Anyhow, got the bath and taken a section of ceiling away in the room below to work out the best place to connect up the bath drain.
Whoever fitted the wetroom decided to cpnnect the sink (at the opposite end of the room) to the waste pipe underfloor, so had used a hole saw through every joist.
Joists are 18cm tall and spaced 40cm apart.
This means that hole is cut through around 8 joists in the same place.
It also looks dead center.
Had the bathroom floor been compromised structurally, or, is it "ok"?
What's the consensus on the additional weight of the bath? Is plumbing it in a bad idea without reinforcing the floor? Or, am I good to go?
