- Joined
- 19 Dec 2005
- Messages
- 101
- Reaction score
- 1
- Country
The pop up waste plug assembly in my bathroom handbasin seems to work fine, in as much that the plug operates perfectly in either the open or closed position. My problem is that the water seems to drain away quite quickly when the plug is in the closed position. Is it possible to fit a new rubber washer to the underside of the plug ?? - do you think that is the problem. If it is where do I get one from ? - or do I have to buy the complete pop up waste assembly ? - thanks in advance i
