I am thinking of converting my attic. Early days and I have a limited amount of money so I want to work with the features that are already there. I have nice deep 8 inch joists, so easy to run pipes etc. In the eaves, very close the the edge of the roof, there is internal cast waste and soil pipes. The access isn't great but I am doing the bathroom under them and have access at a lower level.
The first question is can you have a toilet running into the existing waste stack. The stack is in good working order but the top vents almost flush with the roof and I don't know if there is an issue with having so little height, about 500mm, to vent above the pan connector. Hope that makes sense.
The other issue would be ventilation. I would run a fan so presumably I would vent it through the roof. I would appreciate advice on what fitting would be required to get the 100mm pipe out through the roof and keep the roof watertight.
The rest is reasonably straight forward as hot and cold supply run down the pipe box with the soil stack and the combi boiler is close by in the attic.
Many thanks
Many thanks
