remove the securing screws from the bowl slip a bit of card underneath copy resecure toilet cut out 5mm greater than the line all round
cut the run up to the toilet but dont lay if its a cut board run
then copy on to each individual board cut it 5 mm greater than require if its a good fit remove 5mm from the cut edge at the wall if not you can tinker and line up
if a board only has a bit cut out of and stays whole you will need to cut accuratly although you can still allow for manoover
infill gap with sanitery silicone and flair it up slightly to blend into pan[assuming its white
