Apologies for long, first posting here. I really need some good advice.
Bathroom has two 'downlighters' - both house PAR 38 bulbs, which I understand are generally meant for external floodlighting. One of these packed up a while ago - I swapped in a new bulb, no dice. The wife thinks that the screw fitting was sticky, but I've subsequently confirmed that the bulb screws all the way in. Although recognising there must a fault, I didn't have time to investigate. Some time passed - I suppose having one working bulb meant that it wasn't considered a priority. Fair to say also that the bathroom was also a darn sight cooler as 2 x PAR 38's kick out a fair bit of heat.
Just the other day I pulled the light switch cord and nothing happened. I swapped the bulb that had been working - no luck. I tried the switch a few times and it felt "not right". I removed and replaced. No lights still. I have double checked the wiring at the pull switch. It's a 2-way switch. There are two wires coming out of the ceiling, one is sort of red and one sort of darker red/possibly black. I put one in Com and one in L1. I'm assuming that the switch toggles on and off (so it wouldn't matter if the wires went in COM and L2). I have tried the wires either way (i.e. swapped so that they've both had a go in each respective peg). Tried COM and L2 too!
The wiring at the switch is pretty old, I think, though seems in reasonable condition. I have not touched the wiring behind the two 'downlighters' to which I would have to gain access from the loft.
My experience is basic and rudimentary. I can usually replace a light switch like for like without any problem.
What would have caused the lights to fail - assuming the new bulbs are working correctly. What tests could I apply to understand why the circuit is not working as it should.
Grateful for any advice.
Steve
Steve
