Hi everyone,
I've recently moved into an old terraced house and today discovered a leak under our kitchen sink. This was due to someone in the past failing to blank off an unused end of a 'T' pipe properly.
I turned off the water supply and drained the pipes by leaving all the house taps open.
After I'd fixed the leak and turned the water on I found that I couldn't turn the bath taps off!!!!..... The taps are the 2 into 1 mixer type with the lever to switch to a hand held shower attachment. ... and quite old by the look of them. Seems strange that neither tap will turn off but can anyone help!!!
Cheers,
Steve
Cheers,
Steve
