Hi all,
First time on here.
I am currently doing up my bathroom and have removed all the old tiles.
3 walls are brick and 1 wall is stud. I intend to cover the brick walls with plasterboard and cover the stud with Aqua panel as this is where the shower will be.
Questions:
1) Do I need to tank, Aquapanel (heard various things some say yes, some say no)
2) I will be using plasterboard tape on the new plasterbaord I fit, the plasterbaord will be butted tights and it is squared edged not tapered. I have read you have to seal the tape with joint filler. Will this not give a raised surface where it should be smooth for tiling?
3) Same as above but for Aquapanle joining (using Aquapanel tape) what type of filler is needed (is it the same as normal joint filler?) and will this not leave a rasied section.
4) Finally, I also read that for Hardi backer a PVC membrane should be fitted on the stud wall, is this required? is this needed for Aquapanle?
Thanks for any help
Cheers
First time on here.
Questions:
Thanks for any help
Cheers
