Having lurked in the background, reading post after post, it's time to ask the experts a few questions!
My wife & I recently moved to a 9.5yr old house. Aside from a few squeaky floorboards and some dodgy paint colours (including peach window frames!!), our main issue is with the bathrooms. They're all fine, but not to our taste. The sanitary wear is a little ornate, the tiles are a little "flowery", the gold fixtures are dull and the less said about the laminate wood flooring in them the better.
Having spent a LONG time looking in bathroom / tile shops & brochures, we've decided to rip out all 4 bathrooms and start from scratch. New showers, bogs, sinks & bath, new wall tiles and then floor tiles. And here comes the questions....
It's quite clear from reading this forum that tiling onto the existing cheapboard (sorry chipboard!) is a no-go (especiallly as it's squeaky in a lot of places upstairs anyway). Thinking about overboarding with ply and then tiling, I'm not keen on that one as I don't want a step from the bedrooms / landing into the bathrooms. Instead it looks like the only solution is to rip the chip up and go with some ply.
However, how do I go about pulling up the old boards, when more than likely the run under the stud walls? Are there any inside tips you can give me for pulling up floors around stud partitions? I really don't want to start pulling up carpets / floors in adjoing rooms to get to the other end of the chipboard sheets. As I'll be tiling the walls all the way to the floor, I'll pull the skirting boards if that helps....
Whilst I'm ply boarding the floors, I think it would be prudent to add some noggins for bracing & extra strength (if a job's worth doing and all that..). However, what's the best way to secure the braces if you can't get all the way around the joists (because of walls above, pipes, etc)?
Thanks for your advice, I'm sure there'll be more questions as the project goes on!
