- Joined
- 11 Jan 2004
- Messages
- 43,930
- Reaction score
- 2,884
- Country
Hi guys. Wondered if I could pick your brains a little, please.
We are soon to refit our bathroom. Aside from the window (which we are not altering), we are flexible about where stuff goes.
I cannot draw to save my life, even electronically, so imagine drawing a line across the top of your paper from L-R. That is the external wall, with window. Most of the wall is taken up with window.
That wall is 2540mm long.
Then draw a line T-B on the right hand side at 90 deg to the window wall.
That wall is 2210mm long.
From R-L from the bottom RH corner, at 90 deg to this wall is a wall 1715mm long.
Then the wall returns towards the window wall, again at 90 deg for 560mm.
Then it runs parallel to the window wall R-L for 825mm.
The dimension of the wall running T-B on the LHS is 1680mm.
Hope this makes sense.
OK. Current layout has a bath on the LHS of the room between window wall and bottom corner.
WC is under window in top RH corner.
Basin is next to bath, opposite the window wall.
Door is in bottom RH corner, opposite WC, hinged so that it opens onto the 2210mm wall.
We are trying to fit in a large bath 1800 x 800 and a shower cubicle as well as WC and basin. If the door has to be repositioned, so be it.
What's the best layout do you reckon?
Thanks!
Thanks!
