Hi can someone please provide an explanation?
I had a leak on the ceiling under the shower. It was a gradual leak over time. I removed the old sealant in the shower around the tray and noticed that some water leaked from the ceiling, but not much, I thought maybe it was some leftover water. I cleaned up the leak and I didn't use the shower for a day or 2. I then put the new sealant on, after about 30 - 40 minutes (while the sealant was drying, water started leaking again, this time noticeable leak and not gradual. I am wondering if the drying of the sealant is causing some sort of pressure and pushes air/water out that was still behind the walls? Am I thinking on the right lines?
