bathroom shaver socket
2 May 2003
I want to install a shaver socket to the bathroom. It is with an isolating tranformer, and i would like to fit an FCU. The circuit i am tapping off is lighting 1.5mm radial. Can i run a fused spur off this circuit? There is already one off it for the shower fan? Wasn't sure how many fused spur you can run off a radial? Unlimited??? Also , legally, could i just run a spur straight to the shaver socket? the circuit is protected by 30ma cb, wasn't sure it would be good having the transformer on the primary always on...ie fire regs etc etc.
Cheers
to be honest i am not sure as they may have changed it, but yes you can run a shaver socket off a lighting circuit as it draws so little curent, but you should NOT have a kitchen fan running from a lighting circuit
