Hi All
Got a major problem with the subfloor in the bathroom. At some time or another there has been a major leak on to the floor and the sub floor now resembles wheatabix. A complete corner on one of the boards has broken off and I can see the concreate base under it. The floor looks to be 22mm T & G stuff.
The room is quite small and so the boards go under the walls to the room on the otherside. The walls are perpendicular to the floor under it and the supporting joists run the same way as the wall. Does this make sense? I don't think there is a joist directly under each of the walls.
How best to replace the floor without the stud walls coming down?
Thanks in advance
Pete
Thanks in advance
Pete
