- Joined
- 10 Jan 2016
- Messages
- 57
- Reaction score
- 3
- Country
I have replaced the compression washer valve on my bathroom hot tap many times. The hot tap only lasts about a year before needing replacing again. The hot tap will jam up especially if it is already hot, making it very difficult to get any water out. Repeatedly turning on & off helps a bit.
When I replace the valve I can not figure out what is causing the problem as it freely works in my hand. I have a low water pressure system supplied from hot water tank topped up from cold water tank in loft. Any help or advice greatly appreciated.
