Hi, we are having a bathroom fitted at the moment and I don't know much about tiling - hence why we are getting the experts in. However the experts don't seem to be doing a very good job so far.
We had some very old odd wall cladding removed from the bathroom and the walls behind were OK ish, but not great - I was assuming that the installers would be plastering/skimming, or putting up some plasterboard or tile backing board before tiling to make the walls true. However, I returned home today to find they have tiled straight onto the walls after only a very rough plaster job in a few areas, with only adhesive behind the tiles. The tiles obviously are not square at the corners as it is very visible to the naked eye that the wall bows out about 5-10 mm in places. My questions (before I get stern with the installers)
Will there be some sort of fix I'm not aware of that will make the corners look true and straight? I don't want to get angry with them for them to only say "well we haven't done x yet"
Also is the modern tile adhesive enough to fully waterproof the walls that will get regular showering? I know grout is supposed to be waterproof but in my experience water eventually gets behind there and causes havoc. I expected some sort of waterproof primer/paint/board/sheet or something to be put on the walls first. The tiles are large (58cm x 39cm) ceramic.
By the way this is a large DIY chain installing the bathroom - the tiles cost about £1500 alone so I want it done right!
Hope you can all give me some ammo to use on them tomorrow!
Cheers,
Cheers,
