I had to remove part of the bath panel to access a leak. I managed to remove the panel but porcelain tiles cracked so I need to make good.
The mystery is identifying how the tiler stuck the tiles to the 8mm plywood panel. He did not use tile adhesive but some form of flexible white foam like adhesive which was applied in multiple points under the tile with a "gun".
This adhesive is VERY tough and flexible and it was quite a job removing the tile pieces even after I smashed them all.
I asked in a tile shop and they said this not the conventional way of sticking tiles. They even suggested it sounded like a cowboy job.
Does anyone know what this substance is so that I can use it?
Not sure if the tiler was a cowboy or a genius but it seems to do the job.
Cheers
Marco
Cheers
Marco
