Hi all,
I have recently came across this forum which is a real treasure trove for the DIYer like me (redecorating our first house). I've read dozens of posts and the stickies/wiki articles but still have a few questions that someone will hopefully be able to answer me.
I am planning to tile the floor and two walls floor to ceiling in the bathroom.
I have replaced the floorboards with 18mm ply. I will lay No More Ply backer boards on top and tile on them. Joists are approx. 40cm centres and I am not planning to install any noggins due to time/skill constraints.
The walls are stud walls. I have bought standard 12.5mm plasterboard for the stud wall (I wasn't aware of the green water resistant plasterboards or tile backer boards at the time). I will be tanking the plasterboard in the immediate shower/bath area.
My tiles are 30x60cm and ~5mm thick for the floor and 25x40 and ~3-4mm thick for the walls. I am jot sure but I think they are ceramic tiles.
I am not quite clear on the following:
1. How much of a problem is not having the noggins installed? Is it worth installing decoupling mat to compensate for some potential flex in the ply?
2. Standard advice is to use 6mm No More Ply board doe the floors. Is it OK to use 12mm as I want to raise the bathroom floor to minimise the step (the rooms will be fitted with 20mm engineered flooring ot op of the existing floor boards plus underlay and probably overboarding but that's a different subject)?
3. Will the plasterboard hold the weight of the wall tiles or should I install the backer board instead? I have already bought the plasterboard so don't want to waste it unless I have to.
4. Does the plasterboard need to primed where it's not tanked? I've read something about priming with PVA - does it need to be diluted with water? To what ratio?
5. Sticky post mentions 20mm notch U shape trowel foe the floor. What size notch and shape trowel should be used for my wall tiles?
6. What's the best way to cut out a rectangle in a tile (make it an L shape) so it would fit around the boxed in soil stack? Not sure if scoring would work here?
Thanks!
Vilius
Thanks!
Vilius
