I've read the tiling sticky and various older threads in the forum, and would be grateful if any experts could clarify a few things before I start ordering materials.
Essentially, I have just about finished stripping the plaster from the room. My intention if to use standard plasterboard on the ceiling (to be skimmed then painted), cement based backer boards behind the shower (& around bath?), and moisture resistant boards every where else. I will be fully tiling all walls.
What I wanted to know is whether this sounds right, or whether I would be better off using different types of board anywhere. Also, would i need to tank the boards behind the shower / bath, it using cement based boards and waterproof adhesive & grout?
Thanks in advance
Thanks in advance
