OK;
I' getting ready to do my bathroom and have a couple of tiling questions
I successfully tiled my kitchen and as it was my first ever job it came out REALLY WELL. In doing so I picked up some good tips.
However in prep for the bathroom I have a couple of questions:
1. When tiling a bath should you tile the wall first and then fit the bath and seal between the two or should the bath be fitted first and the tiles applied on top of the bath?
2. If you fit the bath and then tile is there some form of edging that you use to sit on the bath like the kind I see used HERE and what tips can you give to seal the edge.
3. I am planning on removing the sink and in a similar fashion to the bath should I tile first and then fit the sink or tile around it.
4. Dependent on the answer to Q 3, how do I seal the sink, is there an edging strip or do you just use silastic?
5. General Tiling Question - How much adhesive should you apply to the wall, I mean how thick should it be? When you run the tile adhesive applicator along the wall should the applicator touch the tile leaving just ridges of adhesive, if that's the case what size applicator should be used for a wall tile?
Thanks in advance
[/url]
Thanks in advance
[/url]
