Hi All,
New to posting on this site, but found it very useful to read through some of your excellent responses to others' posts in the past.
I recently bought a 1930's 4-bed semi and I've converted one of the 1st floor bedrooms into a new bathroom. I've not added a new soil stack as I've simply used the "hole in the ground" of the old downstairs toilet and put a soil stack into it, which now goes up the inside wall and through the ceiling to the new bathroom. Note that to get the soil stack into the new bathroom I have had to pass it through an interior wall, i.e. it curves round through two turns, but always has a fall on it. There is an air admittance valve on the top of the new stack. All plumbing has been earth bonded by an electrician and the shower installation has been connected by a Part P electrician, as have the bathroom lights. I don't have a fan installed, but there is a night-latched window. Other electrics have been moved out of the room and the light swith is now a ceiling pull cord.
My question is this: Does my conversion need a building certificate? If it does, is there anything above that may contravene existing legislation? I'm especially worried that the soil stack "curves" and that it goes through an interior wall? Reading the part H regulations, I think I've met them, but can't be 100% sure as there is only one para dealing with "offsets" in vertical stacks and it says that these are fine so long as there are no inlets to the stack within 75 cm of the offset, which there isn't in my case.
Follow-on: If I don't get building control, what are the possible penalties and is it still possible to sell the house without it, e.g. with a building regulations indemnity insurance policy? I realise I should have sought building control advice before starting, but on the advice of my Dad, who is an old school builder - I went ahead and now worried I may have to undo the work...
