Recently bought a bungalow (70 years old-ish). Bad smells coming from around the toilet area periodically. Sometimes when it rains heavily, sometimes with no weather change. I have checked and flushed out the pipes going outside into the manhole, no problems there. So I thought the soil stack/vent pipe maybe?
At same time im re-doing the garden and had to dig out the cement around vent pipe and gutter down pipe to lay for paving. They are both cast. I have discovered both original clay bottom part were cracked and in bad condition. So need to replace/fix them, i tried flushing out the vent pipe with a garden hose and put in a bit of flexible stick to see if there was a blockage. That didnt help. Although I noticed that the vent pipe where it bends in the ground to go to meet the manhole/sewer, retains water, it still flows out and doesn't backup, but it sits in the bend about halfway full. Is this normal? Or does it signify a problem? Any ideas appreciated,
