Bathroom touch sensitive light switch?
18 May 2010
Belfast
went to a friends house and instead of the pull cord for the bathroom light they had this switch behind the tile that you just touched. you couldnt see any wiring or any switch.
anyone know where i can buy one?
So why is it that when I did a Google search using the words you chose for the title of this topic, i.e. for the words you already knew you were interested in I got about 23,900 results, including the site securespark pointed you at?
:rolleyes:
Morning All,
I've got four of these in the house - two sensor switches, one dimmer & one bathroom switch.
They're installed behind tiles, making sure that they are isolated from damp grout by fixing the tile with silicone. Damp affects the capacitance and has strange effects. As they're behind the tiles, then strictly speaking they're not in the bathroom, so can be treated as "outside the zones". I DI'd them by silconeing an old credit card to the tile, and then siliconing the switch to that.
They all work well, but have different sensitivities - ie they switch at different distances between the hand and the tile. The dimmer takes a bit of getting used to. Occasionally, a light will switch off for no reason, but touching the tile always turns it on again.
Things to think about in the installation:
1. The LV switches need protecting by a fast blow 2A fuse. The mfr can supply these, but they are cheap & nasty; the sort of inline fuse you would expect to get in Motorworld. Finding somewhere to put it can be a pain as well. I eventually used these in a little DIN rail enclosure:
http://www.rapidonline.com/Electric...fuseholders-for-10-x-38mm-fuses/35047/kw/fuse
http://cpc.farnell.com/bussmann/ktk-2/fuse-fast-acting-2a/dp/FF01107
They don't have a BS number, so strictly speaking can't be used as the sole means of overload/SC protection, but if the light cct is already conventionally protected (eg B6 MCB) then that's ok.
Make sure it's accessible; believe me, you will need to change the fuse when an incandescant blows...
2. The LV switches all have screwed connections, meaning that they should be accessible for maintainance. I've stretched a point by reasoning that the tiles can be removed with a stanley knife.
3. The LV switches can't switch cfl's. They need a minimum 40w load as well. I tried using one to switch a contactor for some cfl's and a 300w mirror heater, but the rate of voltage rise is quite slow (gives a nice soft start effect !) and caused the contactor to buzz. Solution was to use the "bathroom sw" which has a relay 230V op, and a ELV switch (5V I think).
4. The bathroom switch box is a PITA to work with. It's made of hard plastic, and the cable entries are too small for 1.5mm 6424Y cable, so it's hard work with file/stanley knife/sandpaper to make them big enough. Bell wire (for the switch) would fit but as the wire comes into an enclosure where LV is present, the cable must be insulated for LV, so you're back to 6424Y cable.
5. Then you realise that the lid has a lip, which means more scraping...
6. Then you realise that the pillars for the fixing screws for the lid are directly in line with cable entries...
7. Finally, the tunnels for the fixing screws are too narrow for the bit holder on your drill.
8. The LV switch has some tails, but they are fine stranded 0.5 or 0.75mm2 flex, so joining them to t&e is interesting. I put a boot lace ferrule on them, and then used red butt crimps. You could use chock blocks, but remember to allow access for maintainance.
The chap at sensor switch is very helpful - gave me plenty of advice over the phone when the dimmer wouldn't work (manufacturing error !) and allowed me to exchange one ofthe switches for a bathroom switch (with extra £££ !), even though I had already installed it. Got most of the silicone off !
All in all, they're pretty good, though the detail design (to faciltate installation and make it easier to comply with BS7671) could be improved.
Everybody who sees them is impressed; particularly as my wife commissioned some 6" tiles for the switches that cost more than the switches !
Hope this helps, David
And another thing...don't put them behind tiles where they can be splashed - you'll find lights coming on & going off unexpectedly !
David
everyone is a bit touchy on this board. i only asked a bloody question as i couldnt find it myself on google!
Well you wouldn't find any if you didn't look, would you?
And you cannot possibly have looked because it has been shown beyond doubt that entering your own words for what you require into Google does find some.
I fitted this system in the above post around 15 years ago. The firm sensorbility Ltd is no longer trading My system has now stopped working, but ran solid for this amount of time. Is this a thing anymore, or is there a new system not to have a pull switch in the bathroom? I need a new dimmer control unit.
Background on my install.
I fitted a sensor behind part of my bathroom tile, about 5cm sq, to make it a touch sensor. This then connects to a dimmer module control unit, and now runs 5 dimmable LED downright, were Halagons 15 years back.
I'll investigate to see if it just a fuse, but am happy to change the whole unit as its 15 years old.
Hope someone can help.
It's called a switch on the wall, just like in every other room.
Provided it's more than 600mm from the edge of the bath or shower, such things have been allowed for longer than anyone reading this post has been alive.
