You may forget that one day. In an emergency you may have to touch it with a wet hand.I don't touch any switches with wet hands.
And it would not provide the second point of contact ( to earth) necessary for electric shock either for someone in contact ( direct or indirect ) with a live conductor. So onthat count having an earthed metal switch increases the hazard when a fault has occured elsewhere in the room(contrary to what people believe about plastic switches being safer with moisture, plastic isn't earthed so it wouldn't trip an RCD)
They do sometimes appear to contradict common sense when considering a situation involving a single fault. The reason is the regulations have to also cover situations where two or more faults have occured at the same time. Something that the average house owner will never consider.I don't care about regulations, its nonsense,
Then you are an idiot, and your electrician was criminally delinquent to bow to your inane "insistence".when I did by bathroom, I just insisted on a regular 2 gang chrome lightswitch on the wall, I don't care about regulations, its nonsense, and the electrician went ahead and did it
when I did by bathroom, I just insisted on a regular 2 gang chrome lightswitch on the wall, I don't care about regulations, its nonsense, and the electrician went ahead and did it (it's quite big and the switch is out of reach of the bath/shower although it's still in the incorrect zone. There is NO DIFFERENCE between having the switch on the outside of the door or the inside, no matter how many people tell you it's not allowed. I don't touch any switches with wet hands. And pull cords are horrible. My parents' house has a 3 gang switch in the bathroom too, and its completely fine. Better yet, if the switch is a metal plate and is earthed, the slightest bit of water that got in it would trip the RCD instantly anyway (contrary to what people believe about plastic switches being safer with moisture, plastic isn't earthed so it wouldn't trip an RCD)
And you've gone native.We live in an incompetent country.
And in what way, exactly, does that mean that it's OK for you to dismiss safety regulations as nonsense and insist on doing something unsafe?what I mean, is that there are so many things which are actually a danger which are completely missed by inspections, neglected by building control e.t.c.
And in what way, exactly, does that mean that it's OK for you to dismiss safety regulations as nonsense and insist on doing something unsafe?For example, in my parents' house, a council-backed scheme sent 'certified loft installation' installers in free of charge to insulate the loft. The installers had no idea that is was a bad idea to stuff insulation over 60watt recessed lights or over an electric shower cable or over crawl boards.
And in what way, exactly, does that mean that it's OK for you to dismiss safety regulations as nonsense and insist on doing something unsafe?Another big example, is one of the main causes of electrical fires is tumble dryers. There are no government guidance notes on installing ducting, or cleaning ducts, causing many lint fires in pvc flexible ducting, which should be aluminium.
And in what way, exactly, does that mean that it's OK for you to dismiss safety regulations as nonsense and insist on doing something unsafe?They are also plugged into extension leads or 13a double sockets with other appliances which causes the plug to overheat and melt in the socket causing fire before the mcb trips from the shorted flex.
