Hi all, am new to the forum so wasn't sure where this post would be best placed. Hope here's OK
I (or at least my buidlers) have split the master bedroom of my victorian terraced to make an upstairs bathroom.
To date, the existing floor (18mm-ish pine floorboards), have been taken out. Two walls (the corner where the bath will sit) have been plasterboarded and plastered. I don't think the boards are aqua panel or anything special. One of these walls (the stud wall) has several holes / incisions which were made for the first-fixings of a shower. I am intending to tile both the walls and the floor.
I have 3 questions:
1. Will the walls be sufficiently waterproof? I suspect not after reading around a bit. Anything I can do at this stage that doesn't involve ripping down what's gone up?
2. What flooring shall I use? Is 18mm WBP ply sufficient? - I'm keen to keep the floor level with the landing, which will be carpeted. Do I need to seal the surface or the edges / joins?
3. Is normal plasterboard sufficient for the remainder of the bathroom, including the sink area?
I'd be grateful for answers to any of these
Many thanks
Simon
I have 3 questions:
Many thanks
Simon
