Hi guys, hope you can help me with this:
I am currently part way though a major renovation/extension of my home and am in the final fitting phase for my bathroom.
Building control are aware of the project - groundwork started in July 2004 and they have been visiting regularly since then.
I have been doing the electrical work myself and was under the impression that as approval was granted before Part P came into effect, that it did not apply.
I have wired in underfloor heating (fused RCD spur), whirlpool bath (fused RCD Spur), Shower pump & lighting. All wiring has been done in an adjacent utility room with only the manufacturers fitted cable for each device running into the bathroom.
The question is this:
I have recently become aware that part P applies to work finished after April 2005, and hence applies to the work that I have done. Can building control test and approve the work already carried out or will I need to get a spark to check it over?
How much is either option likely to cost (assuming for now that no remedial work is necessary)?
