I just wouldn't put an accessory there, full stop, not sure there is anything specifying an IP rateing, but IPx5 might be appropiate, just incase, though the majority of time X4 would be more than adequate, but as you dont know who is going to use the facities, then you have to design for worst case....
Thanks for the replies and yes RF and fattony that is what i was worried about.
Adam,
Agree with what you say about not putting it there in the first place, its just bad design. The property is going to have a full wiring check so it will get noted down as requiring improvement.
Where I live there is a small downstairs toilet with a fused spur in that position (though not within P-shot). I didn't fit it, but it's for the macerator. I guess you'd know if you had one of those lurking behind your toilet, though. Possibly not the best place for it...
