Bathstore Whirlpool Bath Pressure Problem
3 Jul 2007
Kent
I bought a Whirlpool Bath from Bathstore about 5 years ago. It has worked fine until last week, when the pressure at the jets dropped significantly. I removed the inlet filter, cleaned off the gunk, then flushed the system with hot water and drain cleaner. It seemed to be fine, so I put the filter back on, and thought it was a job done.
The next time it was used, the problem was back. I filled it with the filter removed, and used a wet/dry vacuum cleaner to suck backwards from the filter, thinking there must be some debris, but there was none.
I don't know what else to try, any ideas?
