Batten clips to provide a gap over membrane
12 Feb 2015
Surrey
Instead of leaving the membrane loose, has anyone ever heard of inserts or clips we could add to the battens to create a small gap between it and membrane right in between the rafters?
If you have a router you could run a lot of grooves into the underside of the batten.
Or just trap a length of cable (t & e or flex, not much odds) between batten and felt
Sounds like you are talking counter batoning, if you are trying to keep it to a minimum then you could use 40mm pvc architrave, comes in 5m lengths.
