Hi there,
Just wanted to pick brains.
I am replacing a length of VIR cable at home from an existing junction box to a batten lamp holder. The lamp holder is screwed to the wall, and the cable is and will be clipped direct.
Previous cable was connected behind the lampholder, but as there is no conduit box, this means that that the 'enclosure' is plastic on the front, but bare plaster on the back.
I understood unsheathed cores should be in a full enclosure. I did consider buying a new batten, but when I was in Wickes (just because it is local) all the batten lamp holders looked more or less like this:
http://www.nswoz.com/howtobattenlampholder/ .
So I just wanted to check whether this type of fitting can only be used with a conduit box (my understanding) or whether there is another solution.
Thank you!
Thank you!
