Hi, I'm trying my hand at battening and over-boarding a bathroom in an old 1930s semi we've recently moved into. At the same time I'm knocking the toilet and bathroom into one.
I've started with the bathroom - removed old plaster and lathe from the internal timer frames ready to put up new plasterboard. I'd perfer to batten and overboard the ceiling and external wall.
My first question - in the image below
I'm back to brick where the tiles have been taken off at the bottom. I'd also like to insulate this wall while battening, but I'm not really sure how to handle the parts where it's back to brick. Any suggestions?
Next question is around the ceiling angle -
This really need insulating. I've put some battens up already but the surface I'm fitting the battens to is making it difficult the get the angle of the two battens the same. I'm wondering if it might be better to build a frame and fit the frame to the angled section with perhaps some kingspan in between the battens, then plasterboard on top. Sound reasonable? Any suggestions here?
The side wall -
The side wall -
