I'll be plaster boarding my new extension next month. In another thread I posted on here, it seemed the general consensus was to batten rather than D&D. The walls are all flat and plumb and it does make it easier running conduit and pipework behind. I have since been very lucky to secure about 150m of free tile laths (about 19mm x 38mm), taken from somebody local's roof replacement. This is what I'll be using on the internal blockwork to fix the plasterboard to. I've calculated I'll need about 80 metres (at 400mm spacing) and 25 boards.
Some have told me to use regular brown plugs and 100mm screws, others have said concrete screws (which I have lots of) so between the two I'm unsure which to use. If I got the other half pre-drilling the laths on the pillar drill, it'd be quicker to go straight into the blocks using the concrete screws, however I've not fixed into blockwork before - are these appropriate and are they easy to work with?
