I have a solid external wall & have removed all the old plaster from it.
Should i batten it with 2x1 battens with insulation inbetween, vapour barrier & then plasterboard?
If so do i run battens horizontal or vertical?
Should i treat the brickwork with anything 1st?
should i use treated 2x1?
Or do i build a stud wall in front of the brickwall with insulation, vapor then board.
worried about losing too much of the room as it only a small terraced house.
