I have a twin fluorescent light fitting to put up in my garage, and it also has a battery backup fitted, which obviousley requires a permanent live to charge it. Its the firstt time i have fitted one utilising the backup feature, so im after a little advice from you learned chaps.....Is it just a case of simply giving the fitting a switched and permenant live....eg im planning two put 2 x 1.5mm T&E's to it, one a permenant live and nuetral , and the other a switch wire and a nuetral. Is this correct
