Hi there, I've just been out to start my car (Citroen C1, 2012 plate) for the first time in a couple of weeks due to lockdown. Even before then, I've been working from home since March, so only used my car once a week or so - for short journeys of two or three miles.
Last time I used it, a couple of weeks ago, everything was fine.
Tonight, it wouldn't start - hardly any power so I assumed the battery was dead and got a jump start from my neighbour. It took a fair bit of starting and the jump leads were hot to handle afterwards.
But all seemed to be OK, so I went for a drive of 20 miles or so to stick some more power into the battery.
Early in the journey, the handbrake light (!) appeared on my dashboard, along with the ABS light. Then went off, then came back on again. Whenever this happened, the speedo needle dropped to zero.
I kept driving, wondering if the brakes had seized a little due to lack of use. Then the P/S light came on. Great!
Again, the lights kept coming on on and off. Eventually, they all went out, so I thought I was OK. Then same again. Steering seemed a tiny bit heavy but not too bad.
I got home and reverse-parked my car, noting the steering was pretty heavy. I turned off the ignition, then tried to start the engine again - nothing. Didn't so much as turn over.
Can anyone please let me know what's going on? Is it just that my battery's knackered or could it be something else? As I say, all was perfect last time I drove the car two weeks ago.
If it is the battery, should I try hooking it up to a battery charger, or will it need replacing? Or do you think it's something altogether more serious (hope not!)
Thanks in advance for any help!
