Battery for c&k securitech co23-203 is 1
13 Feb 2021
Does anyone know what battery is required for c&k securitech co23-203 iss 1 we had a power cut last night and the alarm bell was ringing out side with no way to stop it. I done a bit of digging and discovered my battery needs renewed, I am not sure how to do it or what to buy or even where to get it??? Can anyone help ?
The size of battery depends on what you have connected to the panel, I would always opt for the largest the panel can accommodate and charge in accordance with its manual.
you should be able to reset the panel by typing in your user code into the keypad after open the control panel where the battery is stored, I am guessing you don’t have an engineers code. As logging into panel with engineers code before opening up is the best way.
you will see how much space is available and size previously fitted.
