Hello
Don't quite know where to post this query...
I have a piece of equipment that was bought in December 2005. It’s run by a Li-Ion, 7.4v 1500 mAh battery pack. I recharge the battery (8.4v, 0.9amp original manufacturers charger) as soon as the a ‘low battery’ symbol is displayed. I guess I recharge the battery 6 to 10 times a year.
But I’m worried as I’m still using the original battery….
I probably recharged it (maybe) 70 times. Well short of the 200+ re-charge cycles that seem to be the recommended maximum.
The equipment / battery never gets cold or hot.
As soon as the charge is complete, I put the battery back in the equipment.
At the rate I use the battery, will it last another 7 years? Or is there a finite time it will last?
I have a digital volt meter. Immediately after charging - the battery measured 8.31v
One hour later is was 8.29v
Eight hours later it was still 8.29v
Is there a simple measurement I could make - that would give me an indication how much life there is in the battery pack?
You expert thought would be appreciated!
Kind regards - Andrew
