Hi there
I "believe" that my Baumatic dishwasher is causing the RCD on my consumer unit to trip very occasionally. The first time the RCD tripped in the house was about a year a go (although in that incident I don't remember whether the dishwasher was running or not). Since then it has tripped about a half dozen times and each time the dishwasher has been on.
Normally once the RCD is reset I don't experience another trip for weeks or even months.
When the RCD does trip I usually have to wait about 3-4 minutes before the RCD will allow itself to reset. In other words if I push the RCD switch back up/on immediately after a trip it doesn't "click and hold" it just pings back, but if I try again after a few minutes it will eventually remain in place.
On Saturday night the RCD tripped again whislt the dishwasher was on. I didn't turn anything off and after a few minutes reset the RCD. The dishwasher started again but then around 5 minutes later the RCD tripped again. This time I switched the dishwasher off at the socket (but left the plug in) waited the usual few minutes and reset the RCD. The power has been on in the hosue since with no issues. Its worth pointing out that on saturday night I had quite a few things on at the same time as the dishwasher (eg kettle, 2kW Ac unit, projector, PC etc).
Now it certainly sounds like its the dishwasher causing the problem so I'm intending to either replace it or repair it. My question is is there a definitive test that I can do to prove that its the dishwasher? Also since the dishwasher was stopped in midcycle on Saturday night, its still got a lot of water in it...any idea how to get it to drain without having to power it on again?
Many thanks for your help.
Advice for a new dishwasher also welcome. I've already spent £90 on this baumatic this year just to fix the hinge......
