Hi
My new Baumatic oven came with instructions saying it requires a 13a double pole switched fused outlet.
I assume that it is safe to whack on a 13amp plug and plug it into the 13amp switched socket which is on the same panel as a 45a cooker control unit and wired to my consumer unit. Can anyone confirm this is correct?
Would it be better to wire it directly to the cooker control unit and change that fuse from 45a to 13a. Can't see the difference?
