Baxi 100 he plus leaking
23 Mar 2010
Hi all, I have a baxi 100 HE plus which seems to be leaking from behind the pump. Obviously the pressure on the system is dropping and the leak is just getting worse. How do I stop this as I cannot see exactly where it is coming from. Thanks in advance. Danny
pump manifold is a bit of a beeatchh of a job. Just a case of seeing if you can identify which joint is leaking. Stripping down, cleaning up the joints and replacing the o-rings. Check from the top and work your way down when checking for leaks.
Thanks for your help. It was most appreciated. All sorted now.
Its like most things, once you have done it once its not difficult.I have no plumbing and heating background but this was a doddle. Just shows that the prices some of these so called professionals charge is a joke. Thanks Guys.
Hi Danny,
I beg to differ on charges. You are paying for their knowledge. Thats why they charge as they do. You are lucky enough to have picked up the info on this site. As you yourself said......it's easy once you have done it (and know where/what to look for). I guess that applies to brain surgeons too! :LOL:
Congratulations Danny. With some guidance you've fixed a leak. Well done.
As a so called professional I hope you won't be expecting any further help.
I have no qualms with offering advise to people seeking it on here, but remarks of the kind you have demonstrated are the reason why fewer and fewer professionals are posting in this area.
sorry if I offened anyone. it really wasnt my intention. I have just read back through my last post and i now realise how it came across. I do appreciate the help I was just feeing a little pleased with myself for saving money and fixing the problem. Sorry.
