Hello,
I have a Baxi 100 HE which has developed an intermittent ignition lockout fault. It will lockout with a solid red light every 2 or 3 days.
I've tried (temporarilly) removing the earth from the condensate trap to see if that is the problem, but the ignition lockout is still occuring. As it happens, the condensate trap was replaced a few months ago anyway, and is one of the newer, higher ones.
I *think* the fault started after the pipes froze over the cold period. Certainly at some point the condensate drain pipe froze, and water backed up to the boiler and started dripping from the bottom. Since then I've re-routed the drain pipe to stop it from freezing again, but I'm pretty sure the intermittent lockout has started since then.
Any ideas what the next thing to try is?
Thanks,
Adam.
Thanks,
Adam.
