Hi
I've got a Baxi 105 Combi boiler about 2 years old. Recently it has developed a fault whereby the hot water aspect of the boilers operation does not start when a hot tap is turned on. If a second tap is turned on, then the water is heated as normal. The boiler continues to heat the water after the second hot tap is turned off.
I suspect the fault is with a flow or pressure switch within the boiler, a single tap does not provide enough flow/pressure drop to close the switch, whereas two taps will. Once closed there is enough flow from one open tap to prevent the switch from opening again until the tap is shut off.
I have no idea how to go about repairing this fault, or indeed identifying which component is faulty, I'd get a plumber, but despite several promises one has yet to arrive at our door!
Can anyone help me out please?
